Hi,
Are there glitches that you are seeing with the Netflix and Disney+? Recently I have been asked to login in a few times. Just now I pulled in to charge and had to login into Disney again, and then I went to try to sync the rear display for the kiddo and that didn’t work. When I hit the button it asked to login again from the rear screen.
It seems like if you start on the front screen, then the only way to mirror would be to reach behind you and link the two screens. Is that accurate?
I’d like it to be like temperature. Set it in the front and then sync everything else. Am I missing something?
