I've been looking into tires a lot lately while I'm waiting for my konig 18x9.5 rims to come in. I'm leaning towards the Hankook ventus RS-4 tires based on other forum members suggestion and the balance between tread wear, traction, cost and weight.
The ideal size for my model 3 performance is 265/40r18 but I'm thinking of going with the 265/35r18. The 265/35 is about 1.1" smaller in diameter and about 1lb lighter. Smaller diameter and lighter weight should make for slightly quicker acceleration. But the smaller tire will cause the speedometer to read higher and the odometer to add more miles than the car is actually traveling.
Since the tires will be going on a set of rims that will pretty much only be used at the track the speedometer issue is irrelevant and the odometer issue will only have a small impact overall. I know top speed will drop but I have had my car at several events and have never come close to topping it out. If I need to go over 150mph I'll use my motorcycle.
Are there any issues with going to a 25.1" diameter tire that I'm not thinking of?
