miimura
By default, the Powerwalls will always charge from available solar. I can't think of a way to use the currently available settings to stop that.I'm having Powerwall 2.0 + backup gateway + solar installed in January. My distributor limits exports to 5kW but I'm having 13kW PV installed (10kW of inverter capacity)
This means that in addition to "inverter clipping", I will have "export clipping" where (self consumption + 5kw export) is less than PV generated:
For this reason, I want to delay the charging of Powerwall 2.0 until ~10am. This means all early to mid-morning generation is self-consumed or exported. Around the time "export clipped" power should start to be available, I want to start charging the Powerwall.
I have a single tariff and never want to charge battery with grid power. I anticipate that I will be discharging the battery down to reserve level every night due to self-consumption.
I think the configuration I need is something like:
TBC (Balanced)
9pm - 10am Peak
10am - 9pm Offpeak
If I'm reading the thread and Modes of Operation correctly, this should:
- Never charge the powerwall during peak time (even when "excess solar" is available?)
- Begin charging with excess solar at 10am (possibly "any solar" if the Powerwall thinks it will need to?)
- All evening/night consumption will be offset by the Powerwall until it hits reserve power.
Does this sound correct?
The more fundamental question I have is about your electric distributor - how do they enforce 5kW export limit if they allow larger solar systems to be installed? It seems that there has to be some way to configure the solar inverters to self-curtail to meet this requirement. If that is possible, then you would just run in Self-Powered Model on the Powerwalls and let the solar clip after the batteries are full.
The only other solution I can think of is to interfere with the Powerwall's data collection to hide the solar production in the morning so that it is exported.
