Tire Monitor Problem
If there were a way to disable the TPMS altogether, I would go for that. I check my pressures pretty regularly.
+1 TPMS does as much harm as good because of the way it's implemented. A readout of the tire pressures is fine--ideally this would come on when you sit in the car, which is when your really want to know so you can adjust them when cold.
