I just took delivery of MYLR and noted with the decrease in temperature that my tire pressures were below the recommended range. I went to Costco as they have the auto nitrogen tire inflators and thought that would not be a problem to inflate the tires. I did not take off the OEM aero tire wheel caps. I noted that it was very difficult to use the tire inflator at Costco. I ended up accidentally purging 20 pounds of pressure from my tire as it was leaking and I could not get the device to attach correctly. Does anyone else have this problem trying to fill the air at Costco? I suspect after looking at where the tire stem is that I cannot get the tire Inflator deep enough. When I went home to use my own air compressor, I really had to turn the attachment tight in order to get a good seal on the tire. Thanks in advance.
tesla newbie
tesla newbie
