Well said.4 bike racks are tricky. The weight limit on the factory hitch is only 160 pounds. Most 4 bike racks weigh 50+ pounds and if you have anything but the lighter road bikes, it’s very easy to get over the weight limit.
I like 1Up racks, but when you get 4 bikes on the back, they are sticking out pretty far and there is a lot of weight out there. I don’t think the Kuat racks are any better.
Well said.
I just purchased the Kuat V2 3-bike in another thread and it weighs 51 lbs, giving me just enough weight budget for two cruisers and a hybrid or road bike. No way I could do it with a 4-bike Kuat.
That said, the Hollywood Destination 4 platform rack weighs only 42 lbs and could theoretically carry four hybrid or road bikes and stay under the 160-lb total vertical weight limit. I returned it only because it uses a threaded anti-rattle pin, which made it near impossible to use a lockable pin with the stock OEM hitch (due to the towing electrical plug being in the way). If locking the rack to the hitch is not important, or you use an aftermarket hitch, then the Destination 4 rack is probably your best bet for a platform style rack for four bikes. Otherwise, there’s the lockable Allen 4-bike hanging style rack. I have used it in the past but there’s risk of the bikes rubbing against each other and you’d need a special bar to hang step-thru bikes.
Amazon.com
Here’s a pic of the Hollywood Destination 4 and Tesla OEM hitch. It installs fine with threaded anti-rattle pin fully in and a cotter pin, but won’t fit with a key lock. Hollywood customer service suggested going out and picking up several extra thick washers to use on the right side but I didn’t bother since it was still difficult to insert the key in the lock on the left and apparently there isn’t a compatible 90-degree lock due to the threaded pin design.
View attachment 789418View attachment 789419
Right, even though the Model Y factory hitch is rated for 350-lb tongue weight when towing, it is different for something like bike racks. Based on specs of the Tesla OEM bike rack, it is believed we only have 160 total pounds to work with (weight of bike rack + bikes).Thank you so much for the information! Am I understanding that the weight limit on the hitch itself is only 160 lbs? Also, is it better to get the platform bike rack or the hanging one? The hanging one should be lighter, but I am not sure what is stopping the bikes from swinging and hitting each other or the car. Looked at the roof racks but they could probably fit no more than 2 bikes.
How can this be?! 160lbs max weight!?! I was planning on transporting four bikes occasionally!… the only reason i got the hitch actually is for bikes! Lol. Confused how tongue weight differs from a bike rack.. It can pull 3500lbs (supposedly) surely it can hold more than 160lbs!…?Thank you so much for the information! Am I understanding that the weight limit on the hitch itself is only 160 lbs? Also, is it better to get the platform bike rack or the hanging one? The hanging one should be lighter, but I am not sure what is stopping the bikes from swinging and hitting each other or the car. Looked at the roof racks but they could probably fit no more than 2 bikes.
The weight of bikes hanging off a lever and exerting a torque force is different than towing something that is supported on its own wheels and with a max 350-lb tongue weight close to the hitch point.How can this be?! 160lbs max weight!?! I was planning on transporting four bikes occasionally!… the only reason i got the hitch actually is for bikes! Lol. Confused how tongue weight differs from a bike rack.. It can pull 3500lbs (supposedly) surely it can hold more than 160lbs!…?
I occasionally haul 4 bikes with my 1Up rack. Only for short distances and I won't do a bunch of heavier mountain bikes this way.How can this be?! 160lbs max weight!?! I was planning on transporting four bikes occasionally!… the only reason i got the hitch actually is for bikes! Lol. Confused how tongue weight differs from a bike rack.. It can pull 3500lbs (supposedly) surely it can hold more than 160lbs!…?
The factory hitch can generally speaking hold a bit more weight than the rating implies. If you're really serious, get an aftermarket hitch with a 350lb rating.How can this be?! 160lbs max weight!?! I was planning on transporting four bikes occasionally!… the only reason i got the hitch actually is for bikes! Lol. Confused how tongue weight differs from a bike rack.. It can pull 3500lbs (supposedly) surely it can hold more than 160lbs!…?
Search the forum. There are several looooong threads with recommendations/experiences.Just picked up my MY performance and I want to buy a 4 bike rack for the tow hitch. Looking for recommendations on what to buy. Thank you!
The NorthShore rack isn't nearly as deluxe as the VelociRAX, but the 4 slot rack only weighs 50 pounds.Found this info on the bike rack I was planning on using for a 400km bike trip this summer.
our bikes all weigh roughly 30-35lbs so I’m guessing this isn’t gonna fly. Would probably be fine but risking damage to the new car and the roughly $30k in bikes, I think we’ll have to take my buddy’s truck instead
VERTICAL BIKE RACK REQUIREMENTS
- VelociRAX require a class III two inch hitch with a capacity of 500 lbs and 3 - 3/8 inch (86mm) depth past center of hitch pin hole to insert.
- All VelociRAX models can carry 230 lbs. (bike weight)
- Each bike slot can carry up to 55 lbs.
oh yeah?… how’s that working out so far? Lol jk jkPS: Hauling bikes is a big part of why I want the Cybertruck!
Oddly enough, ordering the Cybertruck is what pushed me over the edge to buy the Model Y.oh yeah?… how’s that working out so far? Lol jk jk
It is not a particularly low price for a bent piece of steel tubing and a few bits of rubber. You get what you pay for.
This seems like such a low price for what they are offering. Anyone see this or have it?
