Gauss Guzzler
Safety Score = 42
Just so you know, moving the spring outboard doesn't change the droop behavior. Springs are generally linear (F=kx) so the droop is determined entirely by the weight of the car vs the effective spring rate *at the wheel* and has nothing to do with the location of the spring. A softer outboard spring will have exactly the same droop as an equivalent stiffer inboard spring, even in the extreme case of a torsion rod which is all the way inboard. That's why they make progressive or helper springs.Some sort of articulating rear weight jacks should be installed to reduce spring bow and possibly bind.
A true coilover rear will also eliminate the need for an ultra high rate spring that is too short and becomes unloaded at droop.
And the rear spring only moves up and down by about an inch or so - you'd have to have a pretty crazy spring on there to be at risk of binding.
Aftermarket springs tend to be small diameter to
