Potentially less stress on the subframe bushings and the sheetmetal around the subframe mounts, but more on the shock towers. Will likely need to reinforce the towers or run a cage.What's the motivation? The divorced coil was chosen for packaging reasons and the structure was designed accordingly. By switching to coilover you're putting loads where they weren't intended without recovering any usable space.
Is there some theory that coilovers inherently perform better or are you just wanting to install a system that was designed for a different car?
For coilover type linear rate springs thus the mention of weight jacks above.I doubt it's possible to reinforce this location enough to keep stock consistency. I also don't believe that stock size spring can bend.
This is a good start on a potential structural disaster, with high likelihood of structural failure. Why would you think that this has any assurance of being safe?This is a good start. Clevis mount made and test fit is a success!
And FYI you are correct in that the divorced rear spring "bends" like an accordion as it follows the arc of the lower control arm. But that doesn't make it nonlinear - springs tend to be linear no matter which way you deform them.
What makes it nonlinear is that every part of the suspension - including the wheel and shock - follow an arced path around the control arm but you are only interested in the vertical component of that motion. So the difference between the vertical displacement that you care about and the arced path that the wheel actually takes is what makes the spring rate appear nonlinear.
So if you follow the two points above you'll see that a coilover is just as nonlinear as a divorced spring even though the spring itself is being guided linearly by the shock. Fortunately this nonlinearity is miniscule and is of no consequence to anyone other than academics.
A divorced spring is generally undesirable nonetheless. It occupies more space, requires twice as many chassis mounting points, requires the lower control arm to be much stronger/wider/heavier, and increases NVH by requiring stiffer lower control arm bushings to withstand the constant 750lb force of the spring. No other suspension bushings are subjected to constant forces like that.
Tesla once had grander plans for the Model 3 and it seems they chose the divorced spring setup because it provided space for ludicrously wide rear tires (and also the design could carry forward to the Y for increased cargo bay width).
Looks like those perches promotes bowing the spring. How are seeing bending loads on the shock?Doesn't moving to a coil over then lead to bending load of the shock and thus less linear shock behavior due to the way a spring compresses? It's a tradeoff...
Hydraulic Spring Perches | Spring Seats | Hyperco
Hyperco’s Hydraulic Spring Perches are suspension components used on coil-over springs to minimize lateral forces, resulting in max vehicle performance.www.hypercoils.com
Did you read anything that Mountain Pass said about your ideas? Without a cage it's unlikely you would have the structural rigidity necessary to guarantee safe support of the loads in your coilover idea and there would likely be a significant noise penalty.Some sort of articulating rear weight jacks should be installed to reduce spring bow and possibly bind. Spring seat misalignment becomes more of an issue away from static ride height and further execerbated with a lowered vehicle.
A true coilover rear will also eliminate the need for an ultra high rate spring that is too short and becomes unloaded at droop(unless you use a main and helper spring setup, although doable it is not ideal in a divorced setup). if you have seen how far inboard springs are located on the Tesla and other 5 link suspension, it is sometimes tough to achieve the wheel rates some racers are after. One way around it is to have springs custom made and the other is to run a true coilover rear. Will take a closer look at the rear top mount area before proceeding further.
Already considered that before machined the rear damper mount. Many 5 link rear suspension cars with divorced springs setup didn't look like they would support a true coilover rear did just fine. Tied to a roll cage would certainly be obvious thing to do for a track/race car.Did you read anything that Mountain Pass said about your ideas? Without a cage it's unlikely you would have the structural rigidity necessary to guarantee safe support of the loads in your coilover idea and there would likely be a significant noise penalty.
I hope for your sake you're right.Already considered that before machined the rear damper mount. Many 5 link rear suspension cars with divorced springs setup didn't look like they would support a true coilover rear did just fine. Tied to a roll cage would certainly be obvious thing to do for a track/race car.
