Hello.
This is the UMC connector (European version 230V adapter). This is a brand new cable that came with the car.
After plugging it to a power outlet it flashes red 3 times then there's a brief pause.
There's an adapter that goes to a 230V socket. It seems this is not present in the american version.
This adapter seems quite loose. There's a noticable gap. I am not sure if this is intended or not. Would appreciate input from people that have a similar connector.
I have tried several different grounded power outlets but the result is the same.
I have tried holding the 'reset' button on the UMC and then plugging it to the power source. It stays green for about 3 seconds but then goes back to flashing red 3 times.
I have tried cleaning the connectorsout of any possible dust by blowing air into them.
As a result plugging the UMC to the car causes a 'Charge cable fault' notification on the dashboard and a red ring of light around car's socket.
I am out of ideas and since I have no other cables at the moment the car remains unchargable. What can be the possible causes? Anything I can try to fix it?
Thanks.
Thanks.
