I know the HPWC unofficially supports 277 volt AC. But, does anyone know if the UMC (EVSE/Mobile Connector included with car) supports 277v?
Please see this thread:
Info from Tesla - 277v feed to Wall Connector (HPWC) - Which Cars Support It
Note that it seems like the UMC Gen 1 and Gen 2 did work for one person on 277v, but I really don't think that they officially support it and I am sure there are some NEC/UL issues with running 277v on NEMA 14-50 / 6-50 plugs / receptacles.
The Wall Connector did officially support 277v (fully documented), but then they removed it from the documentation. The reason I have been told they removed it from the docs was because it could cause flaky charging behavior on more recent model S and X units, so it was a user experience issue and not a safety or compliance issue.
Understood that there is no official support. I don't really have a use-case anyway, but was curious about support. Everything indicates that the car's AC charger will accept up to 300v, so it's just a matter of the EVSE handling the higher voltage.
277v NEMA outlets exist (NEMA series-7), they're just not common. Easy enough to build a 14-50 to 7-50 converter.
Yeah, so I am dead curious to see a teardown of a UMC Gen 1 / Gen 2. Anyone have a dead one we can tear apart?
Specifically, I really want to know what the rating of the contactor inside the unit is to see if it is rated for 277v. There are other parts as well that might be meaningful as well (rectifiers for powering the circuitry, etc...) It could be that there is not enough separation between traces on the motherboard for 277v but there is for 240v. So basically it might work running on 277v, but not with the proper safety margins. <shrug>
Bad ass though! I might consider doing it in an industrial environment where I thought the penalty for failure if it melted was low. ;-) Not for your average home user though. ;-)
Electrical supply is rated +-10%. 240 +10% would be 264. Not far off 277....
Wow. 6.4kW at 24A. That's awesome! Some 208V destination chargers don't even hit 6kW at 30A due to voltage sag...
