So today I had a 220km trip starting with -15C and from midpoint to end about -25C. Not only that but also 6m/s headwind. So very rare and quite extreme conditions. Usually at least wind is closer to zero when temperature is below -20 degrees.
So I estimated my consumption to be 260wh/km which gives total consumption of 57,2kWh. I calculated that 90% (430km rated range, ~65kwh usable energy) will be enough and even give me a little buffer to something unexpected.
About halfway at SOC 50% regen dots appeared and I thought thats weird. Checked from SMT and all temperatures were still around 20 degrees but charging/regen was limited at 45kW. Later on around 30% snow symbol appears with cell temperatures at 15c. Last 30km range started to really plummet and blue section in battery image started to grow. Luckily I managed to get to destination with excactly 0km in displayed range. Average consumption was 250wh/km so there should have been buffer more than enough. While planning the trip I thought that waste heat from motors would keep the battery warm enough to not give me blue "range lock" while driving. Cell temperatures were +12c at the end and car was able to charge immediately without warming the battery. Blue bar disappeared again when SOC was around 30%.
Does anyone know if there is something else than cell temperatures which would cause this capacity lock? Or is it normal in lower SOC even with moderate cell temperatures? Never been so low before and capacity lock has only appeared while stationary.
In hindsight I would charge to 100% to give as much buffer as possible if such extreme conditions, but today time was limited. Its also hard to anticipate for everything especially if no previous experience. Just keep in mind that there might occur quite significant range loss while driving prolonged periods in freezing temperatures which you might not be able to count by calculating only energy consumption.
Manual battery heating would also be cool
