Upgrade to performance package after delivery
Discussion in 'Model 3: Driving Dynamics' started by Lucky13, Aug 7, 2018.
  1. Lucky13
    Lucky13 Member
    San Mateo, CA
    I have received my performance model 3 on aero and absolutely love it, but.... I want more. I feel that the brakes leave a lot to be desired and it is probably a combination of the tires and brakes.
    Do you guys think you could upgrade to the PUP calipers(all hardware necessary) with out having to do a software update?
  2. P85_DA
    P85_DA Supporting Member
    Doubt Tesla will sell u parts ...if u want the brakes probably better off purchasing MPP kit
  3. Knightshade
    Knightshade Active Member
    NC
    And if you are talking about stopping in street use you need better tires not better brakes
    Big brakes don’t stop you any shorter the first time you slam the brakes - they let you stop the SAME the 10th time in a row
  4. TexasTeslaRacing
    North Dallas, Texas
    Correct. Better tires are the way to go, not brakes.
  5. Lucky13
    Lucky13 Member
    San Mateo, CA
    Yeah I did state tires as a possible reason. is it me or do the brakes just feel like the lack bite?
  6. stevesnow27
    stevesnow27 Member
    Maryland
    Initial bite was excellent the first 50 miles but after I used them agressively they don't have that bite.
    I want to upgrade the brakes and calipers as well. Hopefully this is offered in the future. I really want it.
    My edit button was gone when they finally announced that the brakes and calipers are upgraded and not just "painted red"
  7. wbhokie
    wbhokie Member
    Woodbridge, VA
    Yeah you really wouldn't notice anything from the performance package brakes and normal driving. Buy better tires first, and if that still isn't good enough, look into the MPP kit.
  8. wallet.dat
    wallet.dat Member
    SW
    I see this posted all the time, but it's not always the case. On some cars the brakes are small enough to completely heat soak the rotor/caliper on the first scrub. Brakes aren't used only to stop the car, but also to slow it down -- say from 120mph to 60mph. The faster you go, the more heat energy that will be created by the brakes, and often times this is more than enough to completely overload the stock braking components on the first try. All it takes is one heavy braking event to figure this out the hard way. It'd be interesting to find out what the upper limit is for the stock non-P brakes. Ie. how fast do you have to be going to completely heat-soak the binders on the first pull?
  9. SigNC
    SigNC Member
    NC
    I keep reading posts about how brake A will stop you just as fast once as brake B just not over and over. While this is completely true a better brake setup can have a much better brake feel and less effort even if they both would be able to stop you the same speed in a one time emergency brake scenario. I think people are too quick to dismiss better brakes with the "get better tires if you want to stop faster."
    Compare a stock master cylinder on a race bike vs a real nice Brembo after market. Both would flip you over the front end of the bike if you wanted to but the feel to get stopped between the two is worlds apart.
    Maybe i'm alone in this feeling.
  10. Knightshade
    NC
    Can you provide any examples of any production car in say the last decade that does that in a non-track situation?
    Because to my knowledge anything made pretty much this century will stop exactly the same the first time from any remotely legal highway speed to zero with both stock brakes and the biggest BBK made for it
    Because the brakes don’t stop the car the tires do
    Now on a track braking usually often from triple digit speeds? Sure- bigger brakes can maintain braking distance over more hard stops, each time letting you brake to the limits of the tires until heat soak sets in and distances start to increase
  11. Petra
    Petra Member
    Palmdale, CA USA
    Considered changing to different pads?
  12. P85_DA
    Not sure why everyone getting worked up about the brakes I drove my P85DL hard for 65k miles on stock brakes and pads and the pads could have easily been driven to 100k miles ..you don’t really need the brakes on these cars
  13. wallet.dat
    wallet.dat Member
    SW
    Sure, any non-Si Honda Civic when loaded down with 3+ passengers (not sure about 2016+ models though). It'll fade on the first heavy braking event from highway speeds (albeit Autobahn highway). Without passengers it's no problem since the brakes won't fade. Bigger brakes have higher thermal capacity, so you'll be able to handle a wider range of passenger/cargo conditions.
  14. Knightshade
    NC
    So...not really then- track speeds as I said
    Also FYI the majority (though far from all) of the autobahn has speed limits these days
  15. Vines
    Vines Member
    Scotts Valley, CA
    I think if you are looking for bite, you should consider alternative pads first, and perhaps upgraded fluid as well.
    From others experiences it looks like the compound on these is pretty soft and not great at high temperatures. Hawk has a couple offerings for these cars,as does stop tech. They would certainly be better than stock.
    Doubt Tesla is going to upgrade your brakes for a reasonable amount, if you really want an upgrade go with the MPP kit, upgraded fluid, and better than average pads.
    Also a tidbit I have gleaned is that the stock brakes have no air pumping shape vanes, and its likely intentional to reduce losses. The stock brakes will always be kinda poor at shedding heat for that reason. I am not sure about the Performance rotors.
  16. shiz
    shiz Member
    TN
    do the stock brakes on m3 require a "breaking in" method such as in the high performance german cars?
  17. SigNC
    SigNC Member
    NC
    I think it's still majority no speed limit but it's getting close.
  18. Warren-RB
    Warren-RB Closed
    Fullerton, CA
    So your "Performance" model 3 is not a PUP? (Performance Upgrade Package?).
    Does anyone here know (or seen) how different of a PUP brake (caliper, rotor, pad) from a standard model 3, or if Tesla has been shipping model 3 w/PUP, if so any picture to share.
    I have done all searches (include sending inquiry to Tesla), but still have no answer.
  19. Knightshade
    NC
    From the wiki on speed limits in Germany/
    German autobahns are famous for having no universal motorway speed limit, although slightly more than 50% of them have posted speed limits
  20. SigNC
    SigNC Member
    NC
    Not that it really matters but if you look into the autobahn specifically it says that ~60% only have advisory speed limit.
