Plastic vs. metal body isn't going to make any difference. I had a (plastic bodied) thumb drive that operated without failure for two years and only got replaced with an SSD because I was running out of room for my music.Just buy those USB drive with a hefty full size metal body, and not those mini ones. It does get hot due to constantly writing large amount of data to disk, and needs the surface area to dissipate heat. Plastic body traps the heat and fries the electronics in the USB drive.
The reason SSD don't fail as easily is because they are much bigger and has the large surface area to dissipate heat. I have had a metal body USB drive in the car for over 3 years now, still working good.
While I only have observational speculation as my evidence, but I suspect that the main reason a large number of these drives fail is because of counterfeit drives. Amazon and eBay are two supply chains I would NOT trust for drive integrity. Just because it says you're buying some famous brand doesn'rt necessarily mean that is what you're getting.
Again: purely my speculation, so don't ask for documentation.
