I've had discussion about the use of EV batteries (while still functioning in the cars) for smoothing the power peaks on the grid. Cars can be charged when supply exceeds demand and discharged when demand is higher. This can potentially eliminate the capital and operational expense of "peaking" generation without dedicating large battery packs to this function. Some people say, "The batteries are sitting there unused. Why not use them to our advantage?" Others feel it would be hard for the utility to properly compensate EV owners for wear and tear on the batteries and other equipment and may make it hard to properly use their cars if they can't count on the battery being full when they need it. Then there are issues of who takes responsibility if the battery fails early.
I've left several options for compensation and charge management. The assumption is that even at worse case, you will be able to set reservations for your planned use of the car and it will be adequately charged at that time. Since at some point there will be a lot more cars on the grid than would be needed for peak reduction, it might be practical that any given car could participate in a minimal way by only allowing the grid to use, say 5% of the EV capacity which would very seldom even be noticed.
If you have any other thoughts I can try to accommodate those ideas as well if there is an option to alter the poll.
