Like many reservation holders, I'm watching video reviews with a lot of interest and it seems that one of the most common complaints is the user interface around changing cruise control speed, autopilot follow distance and windscreen wiper settings.
A way that Tesla could improve the user experience here is to implement temporary scroll wheel functions after these options are adjusted. I know the scroll wheel arrows are also illuminated, so they could make these lights pulse while they are serving a temporary function, so that the behaviour is intuitive. All function changes should be shown on the the relevant section of the touchscreen while being controlled from the steering wheel. I actually tweeted this in limited characters to Elon but like many ideas it was either ignored or lost in the noise.
Example 1: Touching the wipe button to perform a single wipe, could then change the behaviour of the left scroll wheel for a period of about 3 seconds of inactivity. Scrolling up turns the wipers to 'on' and then vary the speed from intermittent to fast with further scrolling up. Like wise, a tap of the 'wipe' button then scrolling down would be used to turn them off again.
Example 2: Moving the gear lever down to set/enable traffic aware cruise control could enable a temporary function on the right wheel to adjust your cruise speed. Likewise, tapping the UI for speed changes could be done with one tap, and further adjustments followed with the scroll wheels.
Example 3: Touching the 'Cruise Follow Distance' option, double pressing the gear lever down or even better, touching the lead vehicle on the UI, should enable the right scroll wheel to temporarily adjust the follow distance. Scroll up to follow closer, scroll down to follow further.
There may be more functions that could be improved by using temporary scroll wheel functions that you can think of?
Thoughts? Improvement or not? Better ways to do it? Or do you like these common controls being touch UI only?
