I have just had a Neurio W2-Tesla Power Meter installed on my Wall Charger gen. 3.
As it is common in our area, our house is limited at a supply of 3 x 25 A at 230/400 V.
It means that Dynamic Power Management is often necessary to avoid overloading, especially in homes with other high-load devices like heat pumps or instantaneous water heaters. Even our oven in the kitchen, with its 2300 W grill on one phase (10 A), together with EV charging at 11 kW (3 x 16 A) will get us above the 25 A at one of the phases.
The data cable between the Wall Charger and the Neurio Power Meter needs a single twisted pair for the RS485 connection. I used a standard Ethernet CAT 5E cable.
After connecting the two data wires, and the four power wires and the three CT clamps in the correct L1, L2, L3 sequence, the configuration via the Tesla One app to set the maximum current (the 25 A) is straight-forward. No other configuration is needed. The Tesla documentation does not mention any option for the Neurio to be connected to WiFi when used with Dynamic Power Management, only the data cable is needed.
The installation and configuration went without problems of any kind; I followed the instructions here: https://www.tesla.com/en_EU/support/charging/wall-connector/power-management
I tested it the following way:
However, one thing seems not to be described by Tesla: What does the colors at the Neurio LED mean? As seen at the linked video below it is green most of the time, but red approximately once every second. Does it mean that everything is as expected?
Tesla has some documentation about the Neurio LED, but when used with a Powerwall. However, it does not list the color combination I have. It may also be that the Neurio for Dynamic Power Management is a very different firmware than the Neurio for the Powerwall.
Does anyone of you have the Dynamic Power Management already installed, so we can compare the LED link color patterns?
Peter![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
- Started 11 kW charging at my Tesla
- While watching the Tesla app for the charging power, I turned our oven and other heating appliances on one by one.
Peter
