Ah ok. sorry I didn't know what you meant... Sure.
Done that with charging already
The problem is with the net monitoring
I've done a deep dive on some other threads.
The app (and in fact the whole Tesla cloud/smart ecosystem) needs net metering at the
main board to function properly.
In a two phase set up, if the PW isn't monitoring the main board, it operates as a separate entity, ie charges, discharges, backups just that one phase... It works fine doing that... sure.. but you lose some of the Tesla smarts overall.
For example right now?.. sun comes out, so PW starts to charge ...sucking
all the solar. That means the other phase (without solar) pulls power from the grid (rather than being balanced at the meter as a net export)...
I've learnt that I could use a Neurino Wifi monitor at the main board...pull that info into the Tesla app to improve things but that's another $500- maybe more spend. And apparently they can be a bit flakey...
Alternatively I could only charge the battery when there is enough solar to cover the entire load (battery charge + the rest) on that phase..so wait till there is more solar power. Ok now in Summer (I collect 6-7KW 10am-3) but winter will be more of a problem
I've asked about some setting where I could set the PW charge rate, or limit it to charging at say 2KW or something, but there are no such setting. If I hardwire throttle it with resistors or something I will negate the warranty
It looks like it's going to be easier simply adding solar and a PW3 on the other phase (which I want to do anyway) and running the house as two separate systems
The app doesn't summate this as one, but I can do that anyway in Home assistant.
I'm lucky I just started out adding one PW and waiting to see how it all will work - build my final off grid (that's the aim..I'll eventually need 45KW storage anyway to cover winter)...so slowly as the tech settles
The main house needs more peak load anyway (thats where the stove, kitchen, heater etc is)
So PW3 will be ideal
I need more PWs as it is
(I'm in Melb afterall)
Thanks for your help.
Cheers.
