So I'm trying to figure out if this would work/ be to code so any electricians that can chime in would be of help.
My plan is to feed a 125amp sub panel from my main with a 60amp breaker/feeder. In the sub panel I'll install two 60 amp breakers and wire these to each gen 3 wall connector. I'll setup power sharing to pull no more than 48 amps between the two wall connectors at 1 time. Is this acceptable?
