I currently have a 4.8kW system with Powerwall+. The Powerwall+ is backing up 100A load center that is in turn connected to my 200A main panel via a 100A breaker. The 200A panel upgrade was done by Tesla at the same solar installation project. My house is small, so the 200A main panel only included the 100A Powerwall breaker, and nothing else.
Because the 100A load center is already filled, I installed my Gen3 Tesla Wall Connector into my main panel. The installation and setup all went smoothly; the charger is working as intended.
However, the Tesla app usage reporting across my house is now all messed up. Typically, the idle load on my house is ~0.3-0.4kW. When the car (a Tesla) is charging at 32A (drawing 7kW), the Tesla app would show home usage at 0kW, and the car usage as 0.3kW. I believe I should be seeing 7kW for the car, and 0.3kW for the house in the Tesla app.
I suspect that my Tesla app is not monitoring any usage outside of the 100A load center. Has anyone encountered similar issue? Has anyone been able to get Tesla to monitor the whole house (i.e. include circuits in the 200A main panel)?
