It feels like it’s locked and just won’t release - I’ve tried to tug on it and pull it out and it started to flash 3 red lights so I turned the breakers off and on and then it’s fine back to green but it still won’t release the charge handleCharge handle stuck in the side of the wall connector? If so, nothing electro-mechanical there. Just held in by the angle and a catch.
Does the wall charger connect to the app? (Sorry I’m fairly new, just got my Tesla Y a few weeks ago) The connector is stuck in the wall charge itself and not the car.Try ‘unlock charge port’ from the app
Once you hear a thunk, you should be able to remove the connector
Dumb question - but is your car unlocked when you try to remove the handle? I made this mistake a couple of times when I first got the car.Just had Tesla wall connector installed and it was working fine but tonight went to pull the charge handle out of the wall connector and it won’t release. Anyone had this issue?
Unfortunately it’s not in the car - it’s stuck in the wall charger itself.Dumb question - but is your car unlocked when you try to remove the handle? I made this mistake a couple of times when I first got the car.
Have you tried lifting the handle before pulling it out? There's nothing holding it in besides gravity. Otherwise you might have some sort of defect that caused it to be stuck. But if you can lift the handle easily you should be able to pull it out.Unfortunately it’s not in the car - it’s stuck in the wall charger itself.
Yes! I tried that as well and nothing. I am able to wiggle it around, push up and pull but it just won’t release.Have you tried lifting the handle before pulling it out? There's nothing holding it in besides gravity. Otherwise you might have some sort of defect that caused it to be stuck. But if you can lift the handle easily you should be able to pull it out.
Tesla branded wall connector? Gen3?It feels like it’s locked and just won’t release - I’ve tried to tug on it and pull it out and it started to flash 3 red lights so I turned the breakers off and on and then it’s fine back to green but it still won’t release the charge handle
It's just a notch inside you lift the handle up to release it from the notch as @lgibson said. The handle is only held on with gravity and the weight on the cable end it's not electronic. You can see the little square notch on the ones that you print.Unfortunately it’s not in the car - it’s stuck in the wall charger itself.
