Mark Z
A: I have 200 Amp service from Edison and it is sufficient, however I do have a separate meter for the electric vehicles. Edison split the wiring to both panels.Questions: (A) Is 200A home service sufficient? I realize it has to do with the current power load, but I doubt the builder went 100A overboard. (B) Will the car always draw 72A until full or will it recognize available power and adjust? ..concerned about rest of house browning out. (C) Is a 100A sub-panel advisable, or overkill?
B: No automatic adjustment takes place. You can manually lower the amount of amperage to as low as 5 amps at the touch screen of Model S or X. For overnight, I always lower the amperage. The GPS remembers your last setting at each charge station location.
C: Check with an electrician about the sub-panel. Since a circuit breaker in the main panel would be used for a sub-panel it may not be necessary unless electrical code or city planning requirements dictate that solution. Having an electrician that other electric vehicle owners have recommended would be my suggestion.
The other reason to check with local codes and an electrician when considering a larger than 60 amp circuit breaker installation is the requirement for a cutoff switch near or at the Tesla Wall Connector (HPWC). That switch adds to the cost of installation and the space needed. Check the electrical code requirements in your area.
