If you got "Pin to Drive/open Glovebox" set, suggest disabling it, as you may not be able to drive car/access glovebox.I get this error today
Both good pieces of advice, however the way this message is worded it sounds like they might have put in place some work around, when in the display-rear-camera-only mode maybe the PIN to drive and scheduled charging get disabled automatically (hence the press the brake for 30 seconds)? It would make sense from usability point of view but I guess we won't find out until someone with PIN to drive gets to the display-read-camera-only mode (perhaps it should be called limp mode?).Also turn off scheduled charging as the car won’t know the schedule if your emmc dies and can’t charge.
Would you elaborate? If you are still able to do non-schedule charging, what does disabling schedule-changing would do?
If you plug in with scheduled charging, charging will not start until that time. If the MCU dies, there is nothing to tell the car to start charging.
Yes, I understand that I lose the scheduled-charging capability. But what good does disabling scheduled-charging do if I'm still able to charge? From what @kdday wrote, I read the disabling the scheduled-charging is the requirement to do any kind of charging, scheduling or not. I guess I'm trying to understand why it's good to disable the scheduled-charging when I won't be able to scheduled-charge anyway but I can charge just by plugging anytime and start to charge?
Normally, when you plug the car in, it will charge if the charge set point is higher than the current SoC.
If scheduled charging is enabled, it will override that, and no charging will occur even if the above is true.
If the MCU dies, you won't be able to charge in this case.
Much has been written on this elsewhere on this forum.
I realized what I was missing after I posted my response. I see the point now and agree. Sorry for the confusion.
I suppose we are only talking about the AC charging, since hopefully the supercharging still would work, correct?
Also, curious to find out the disabling the scheduled-charging is a good idea for any car exhibiting possible bad eMMC or just being recommended after the eMMC repair warning message pops up?
I thought maybe you were thinking of the fact that one can override the charging schedule and charge now using the app, but with the MCU dead there is no more app...so that would not be possible.
You need to read this thread again; at least the first wiki
