NCM, but yes the Chinese LG 2170s are the only choice that makes sense. Despite some people with unsubstantiated beliefs to the contrary.Hi everyone - is the consensus that 2023 US-built Model 3 LR use LG 2170 cells? I’m assuming those are NCA cells?
I'm gonna go out on a limb and guess it holds about 75kWh. Just like back in the day (in Europe), and maybe now? Guess we'll get an EPA document at some point! Just not posted yet.I think once we see how many kWh of energy the pack holds from 100-0%
This apparent conflict is not evidence to be considered as the Model 3 RWD, which is 100% certain to have Chinese-made cells, is also currently eligible for the full $7500 tax credit.That it qualifies for the $7,500 US federal tax credit and is thus in direct conflict with US federal law has yet to be resolved. I have reservation over the apparent conflict.
I’ve wondered what the definition of “assembly” is. This may indeed by the loophole. Hard to believe bringing cells in and putting them in packs qualifies, but I’ve not seen it defined. Been many months since I read the language though so…. In aviation “assembly” (this for experimental work) is defined by the majority of labor. If the EV credit bill doesn’t define same, well, more power to Tesla. Given Manchins rigid leanings and demands I’m surprised. If so that would sure lay rest my reservations. It would also flow with LG‘s US construction plan, save for the pretty obvious year or so gap.They are most likely importing raw cells and just assembling the modules/pack in North America to get around the North American assembly requirement.
I tried plugging my car into a v3 charger and the most I got was 170kw... a really long away from the supposed 300kw max the car supports. I'll make sure I'm at a more empty charging station next time, when I plugged in there was someone on all 4 slotsAnyone got a charging curve for the M50 packs? Curious to see how they perform
Are they the same packs that have been used in 3/Y P/LR in Europe and China? Peak a bit lower than 250 kW at single digits SoC and linearly goes down from there?
Worse than the Panasonic US cells but not by that much
As @GhostSkater says, 250kW max.I tried plugging my car into a v3 charger and the most I got was 170kw... a really long away from the supposed 300kw max the car supports. I'll make sure I'm at a more empty charging station next time, when I plugged in there was someone on all 4 slots
This is actual logs from Model Y LR made in Germany that use the same LG 78.8 kWh as the model 3 get in Europe. Teslalogger never did split model 3 in land of build so there is no clean data on M3LRAnyone got a charging curve for the M50 packs? Curious to see how they perform
Most probably, yes.Are they the same packs that have been used in 3/Y P/LR in Europe and China?
The older Panasonic 2170, 77.8 kWh (2018-2020) is the fastest charging ever in model 3 so far.Worse than the Panasonic US cells but not by that much
Why is that hard to believe? It's common that battery cell manufacture is distinct from assembly & pack manufacture, as the expertise involved is distinct and cell manufacturers provide to multiple end manufacturers.I’ve wondered what the definition of “assembly” is. This may indeed by the loophole. Hard to believe bringing cells in and putting them in packs qualifies, but I’ve not seen it defined.
In aviation it's common that electronics and engines are supplied separately from the airframe manufacturing, correct? And aviation assembly does not count engine manufacturing or the same for electronic components----Boeing doesn't run a chip fabrication plant.Been many months since I read the language though so…. In aviation “assembly” (this for experimental work) is defined by the majority of labor. If the EV credit bill doesn’t define same, well, more power to Tesla.
The law gets more strict every year for US/allied sourcing of cells and packs---the intent is not to encourage EV sales to end users as policy but EV manufacturing choices. And it works as without this almost all new factories would be Chinese.Given Manchins rigid leanings and demands I’m surprised. If so that would sure lay rest my reservations. It would also flow with LG‘s US construction plan, save for the pretty obvious year or so gap.
i think i would know what type of car i bought thanks.You sure you have a Long Range one? 170 kW is the maximum the standard range can do
Also, make sure you set the Supercharger as destination so it preconditions the pack, and no Tesla currently can do 300 kW, max is 250 kW
I’m quite sure the current m3 model in US only supports 250kW (supercharger V3).the second time i plugged in it was a less busy station and it jumped to 210 at 19%.
and as i have stated from before, the 333 mile range model 3 has support for 300kw charging.
Yep. I see all that.
Anyway, this doesnt mather.
The LG batt in the latest 333mi version (if it wasthat version) will not go past 250kW, in fact it will struggle to resch 250kW.
You can see in the graphs that it barely reaches 250kW if you connect the car 0-5%. Starting the charge above this number will reduce the maximum power.
The reading on the screen includes the battery heat that is on for the first part of the charging session, so some 6kwh or a little more should be subtracted to se the same value as in the graphs above.
My top reading is 261-262kW, (M3P 2021) that included battery heat and cabin heat and the charging power into the batt was 251.75 kWh.
