1) I have read that the foam can prevent the sealant from fully getting to the puncture site and sealing the leak.1. Will the sealant (in a can) work if the tire has the acoustic foam? can it make it to the puncture site?
2. And in the case it does work. What would happen when you eventually make it to a tire shop. Can they remove the sealant and do their own "proper" patching job? Or is that it for the tire? (you must replace with new tire).
3. What about in the case of plugging? Can the tire shop remove your plug and do their patch or do you have to get new tire?
4. Does the use of the canned sealant have the same limitation as plug/patch in terms of location (i.e., cannot be used if puncture is on/near the sidewall)?
2) Tire shops universally hate the foam and hate the sealant. They are likely to refuse to attempt to repair the tire. (Once you replace the damaged tire you would be able to attempt to repair the tire on your own, keep the tire as a spare.)
3) For liability reasons, these days, tire centers generally refuse to repair any tire where a puncture has already been repaired by the owner.
4.) The sealant can't be used to repair a damaged sidewall.
I would only consider a repair as permanent if the damaged tire that been patched (from the inside) else plugged using a good quality tire plug kit.
At one time, when bias ply tires were the standard and radial tires had yet to become the norm you could install an inner tube inside a damaged tire and be able to drive on the punctured tire for the life of the tire. The requirement for tire pressure monitoring sensors in the wheels attached to the tire valve, precludes using an inner tube.
