Both.Thanks Matthew, do you know if the charge limiter is part of that or is the logic to control the charge level part of the car converter inside the car?
By charge level, you are referring to the charging rate in amps?Thanks Matthew, do you know if the charge limiter is part of that or is the logic to control the charge level part of the car converter inside the car?
YesBy charge level, you are referring to the charging rate in amps?
Pushing the disconnect tells the AC 2 DC converter in the car to stop using power which it quickly ramps down using the power transistors (or similar technology), then tells the box to open the relays and the car unlocks the charge port.This also prevents arcing when plugging in the car which would, over time, cause high resistance at the connection. That's why you have to push the button to disconnect as well - it tells the car to tell the box to turn off the power and then the car lets go of the plug.
No one knows how the charging system works but they know how to sell it.
They don't even need to sell it. My opinion is that Tesla could fire all of their sales people and they still wouldn't keep up with demand.
Still waiting to take delivery of my Model 3 later this month, so apologies if this question sounds ignorant. I have a 240V outlet in my garage to charge the car. Are you saying I can plan to keep the Tesla-provided charging cable attached to the garage outlet, and then not bring the cable with me in the car for on-the road charges, since the on-the road chargers all have built in cables? I assume the j1772 is a Tesla-provided adapter so I can use those on-the road charging stations?I believe it. Just salesman.
I used the portable for a year. Never unplugged to bring it with me, except twice when I visited family.
Did replace with a WC to take advantage of a local utility EV charging opportunity.
But realistically I only used supercharger or the j1772 adapter on the road.
There's also a temperature sensor in each pigtail at the end that plugs into the outlet. If the plug gets to hot (likely due to a poor wire to outlet connection or plug to outlet contact), the box will detect it, interrupt charging and indicate a thermal problem.A microcontroller, a relay or two, and some circuitry to provide the right signals to the car. Oh, and a GFCI.
