Which is easier to lower?
Discussion in 'Model S: Driving Dynamics' started by John925, May 30, 2015.
  1. John925
    John925 New Member
    San Ramon ca
    I am ordering a 85d soon and plan on getting some 22" wheels. Which suspension is easier to lower? The standard coil suspension or the air suspension? From searching it seems one just needs to change the links on the air ride cars. Any help for a newbie appreciated.
    John
  2. beegee
    beegee Member
    Wentzville, MO
    The air suspension has a selection for "low always" if that helps. It can actually go even lower, but is limited by the software.
  3. relagustin
    relagustin Member
    Sacramento
    Lowering links on the air suspension is really easy. I installed mine in about a 45 min. It's a little tough without taking the wheels off, but I was able to do it by just using a floor jack to raise the corner I was working on. Make sure to use jack stands for backup.
  4. Zextraterrestrial
    Humboldt/Los Altos
    Air is super easy
  5. arijaycomet
    arijaycomet Member
    Cleveland, Ohio
    I've lowered both cars--- and now there are even springs for the coil cars. But the only real DIY solution is links, and air suspension. If you go links, I suggest:
    Audi Porsche Bentley Mercedes Volkswagen Range Tesla Rover Lowering Kits
    Those can be done yourself... but if you go low enough you'll need to consider adjustable or different rear upper arms to resolve camber (otherwise, be ready to replace tires often). No matter what you do, after lowering any car, a four wheel alignment is always best.
