Probably wrong season, but noticed in the winter than hvac enable AC at low temp even in dry conditions. Why is this? I generally used manual and turned of AC as consumption was quite a bit higher. Even in light rain windows don't fog without AC. In heavy rain or high temps AC is required, but I don't understand why it's active in low temps as it lowers range quite a bit. Any insights?
On the Kia Soul and Nissan Leaf with heat pump AC is very rarely active in winter as you can' t use AC for both heating and drying/cooling at same time, but fog is rarely an issue except in heavy rain.
