Why not have US Military build solar and wind, go carbon neutral?
US Military owns 8,849,476 acers, can easily build enough PV and Wind to power all buildings, and then offset carbon from military vehicles.
And then pay less to operate everything.
And since its under control by the CinC, all he has to do is make an order (and they will have to do budget somersaults)
Thoughts?
You know that many of those acres of land are used to drive things on, drop things on and to explode stuff, so not really usable.
However, examples:
It's not like they aren't looking at it.
Reactions: MontyFloyd
ItsNotAboutTheMoney is right - you need large (and I mean really large) pieces of land (huge, square miles of land) for live fire exercises, maneuver room for troops and tanks, etc. firing ranges, and training areas. We'd go out in the field for weeks at a time and cover miles and miles of territory during our field exercises. We'd set up our 155's in a location and start dropping shells miles away from our position; then pack up, move and do it all over again. You need empty space to set up, empty space to fire over, and empty space for the impact area. If you're doing integrated training (troops, field artillery, tanks, etc.) then you need even more room to be safe and to give everyone enough space.
Good idea though
Good idea though
Let me reiterate, the amount of land that is NOT used for live fire and training is far more than used for training.
For example: Ammo depots.
These are vast areas of isolated bunkers housing ammo. It is extremely rare for ammo depot to explode, the last in USA was during WW2 (in storage, not during transport). Covering that land with PV will make barely used land to easily power a local base and civilian areas.
Here is an example, easily 10 square miles of that cannot be used for any training.
Then you can look at motor pools, parking lots, large buildings, aircraft hangars, etc.
More than enough space to generate gigawatts of PV.
You cannot put solar on munitions storage igloos. There are requirements such as the depth of soil on top to the thickness of the concrete. Minimum distances from buildings. Minimum distances from other explosive storage sites. No base will put solar around or near their flightline. You may be able to put solar on some buildings but not all. You will also never see solar certain types of aircraft shelters/hangers.
The military has been looking at renewables for some time to help solve daunting logistical challenges. Today's military consumes enormous volumes of petroleum based fuels. Getting fuel to ships at sea, to ground forces deployed overseas at remote areas and to aircraft operating from austere locations is not only expensive, it is often done via a fragile supply chain that could easily be disrupted.
So what is being done? As sited above, solar is one potential avenue. Some are more innovative and are in the early stages of R&D, but imagine being able to capture carbon to produce fuel via the technology outlined below:
I'm sure there are other initiatives being investigated to help solve the military's logistical challenges, but it won't surprise me if some of them end up benefiting all of us.
This chart list Inhabited buildings or active roadways. The 605509-M-V1.pdf is guide about handling AE and power of explosives, and acceptable practices. Nether mention limits to non-Inhabited structures, nor limits to how long a patrol unit can be in area.
A QRA could be forwarded that installing PV in some areas in proximity to AGM would be acceptable.
Slide the bar at the bottom of the page
Chapter 9
Everything here is summed up in
C1.1. GENERAL
C1.1.1. These explosive safety standards (hereafter referred to as “Standards”) are issued
under the authority of DoD Directive 6055.9E (Reference (a)). These Standards are designed to
manage risks associated with DoD-titled ammunition and explosives (AE) by providing
protection criteria to minimize serious injury, loss of life, and damage to property.
This does not prohibit building anything within the blast radius, (referring to first post only another magazine quote "Separation of magazines" (thus excludes all other structures), this is to insure there is no chain reaction of one magazine setting of another.
PV are inert. Worst that could happen is a number of panels are damaged/destroyed (assuming no personnel in area by chance).
Put in another way, if the base wants to install structures such as security cameras and even the specifically mentioned barricades, there is no issue.
Yes, in the incredibly unlikely case of an AGM exposition there will be loss, but not a chain reaction of panels blowing up.
There is a specific mention of power grids:
C6.5. ELECTRIC SUPPLY SYSTEMS which limits to 50ft minimum from the Magazine and buried, there is no prohibition outside of that radius.
Back to my earlier example here, there are clusters of AGM that are separated 2000ft (!). Lets be generous and have a 200ft exclusion zone around the AGM cluster, what is left is a 1600 ft wide strip of land that is unused, 15840 foot long (can be 21120 ft if one wants to stretch it), 2,5344,000 sq ft of usable land.
And that is just 1 small strip of land.
I do not see anything in the document that prohibits installing a PV array within 50ft radius as long as the power cables are burred (lets go with 200ft to add extra safety but still have plenty of useable land).
Maybe I missed something, so please be very specific as to what sub section you refer to.
For God shake. The President screaming for Green doesn't own an EV or have solar panels on his home.
The WH should also be covered in solar panels and have EVs everywhere.
Walk the Walk. Just too much talking and no walking.
Not until the leader leads, the army sits.
