Had my first mobile service…It’s coming up on two years so I decided to change the air filters. While mobile tech was here I had him check tires since I only put air in as needed…no other tire maintenance performed….ever.
I was surprised with the even wear….fronts listed as 4mm left and rears at 3 after 23k miles. I would have rotated if I thought I could get through next winter…these are the stock Michelin Primacy mxm with 23.5k miles on them. I’m sure I’ll be down to 2-3mm by October and I don’t want to run another winter on them.
What have others experienced with no rotations? If wearing even, does it make sense to rotate other than because others are? Are there true performance gains otherwise?
Anybody have significant difference between front and back? Example: 6 in front vs 2-3 in back?
Trying to understand value and gain….and if I should plan to rotate my next set. Pretty sure I’m going with conti DSW 06 plus.
