Windows don't always go all the way up when door is closed
Discussion in 'Model 3: Interior & Exterior' started by Trevor B, Jul 30, 2018.
  1. Trevor B
    Trevor B Active Member
    I've noticed this a few times when closing the door (from outside).
    The window stays in the lowered position it was when the door was opened. If I close the door a 2nd time, it goes back up.
    I have the latest firmware (2018.26.3 be4b11e) update, fwiw
  2. P85_DA
    P85_DA Supporting Member
  3. Trevor B
  4. SMAlset
    SMAlset Well-Known Member
    SF Bay Area
    Don't have my Model 3 yet but do remember this type of issue on the Model S forum. Someone had an explanation there how to reset the windows. I'll see if I can find the thread otherwise do a search on the other forum.
  5. SMAlset
    SF Bay Area
    This is the process I remember reading about in the Model S forum. BTW this has happened to me in my Toyota Avalon and I did this and it cleared it.
    If your window buttons wouldn't work at all, which doesn't seem to be your situation, it might be due to a button regulator which would require a service visit. Here's the post from a guy in that situation:
  6. El Doggo
    El Doggo New Member
    York, PA
    I just had the same issue with my new Model 3. The front passenger window stayed down (on a rainy day) and I came back to a wet seat.
    I hope/suggest that a future upgrade allows for a Notification to be sent when we walk away from the car with a partially open door and/or window
