Wireless phone charger 3/Y MagSafe
I wanted to share my solution. Parts list:
Phone holder (no charging) - Spigen OneTap Designed for Tesla MagSafe Car Mount Compatible with Model 3 / Y / S (2021) / X (2021) Ford Mustang Mach-E Compatible with iPhone 13 Pro Max 13/13 Pro 13 Mini/ 12 Series
MagSafe charger holder fits the above phone holder - Spigen Mag Fit Phone Holder Car Mount Designed for Magsafe (Charger Not Included)(Requires USB-C Car Charger)
L shaped USB-c - UGREEN USB C to USB C Cable Right Angle 90 Degree Type C 60W PD Fast Charge Compatible with Samsung Galaxy S21 S20 Z Fold 3 Note 20 Google Pixel 5 4 MacBook Pro Air iPad Pro Air 4 Mini 6 Switch 3FT
Female to female USB C* - USB C Adapter Female to Female Coupler,3 Packs PD 100W Fast Charging Type C Extensions 10Gbps USB 3.0 Connector Compatible with Samsung S20,S10,Fit for Pixel 2,3 XL,Nexus 6P,for Huawei Mate 20,P20
* this connector is a little finicky - only a certain orientation works - so switch sides until you get a good connection
Apple MagSafe charger - Apple MagSafe Charger
Magsafe case - Spigen Mag Armor Compatible with MagSafe Designed for iPhone 12 Case (2020) / Designed for iPhone 12 Pro Case (2020) Magnetic Charger Compatible - Matte Black
  • Very easy to place the phone/take out
  • Phone is very stable (and position is adjustable)
  • Pretty clean install. Cables are mostly tucked under trims (see picture of cable before placing it under trim)
  • Phone does not auto-lock due to its position/Face ID - (I have a corporate policy on my phone that does not allow to cancel auto lock.) - make sure you go to Settings - Face ID & Passcode - turn off "Require Attention for Face ID"
  • Phone does not block the view
Dislikes
  • aesthetics are not perfect (might improve with a black sticker/skin on the MagSafe)
  • Phone is slightly blocked by the steering wheel
View attachment 730230View attachment 730231View attachment 730232View attachment 730234
can I ask the OP how the Apple MagSafe charger works with this setup? I got the first spigen one tap holder, but the apple MagSafe doesn’t fit in that. And I see another holder, but how does that integrate with the first holder.
Works very well. You have to buy all the components in my list. You have to use this part for the Apple charger - take the original part out of the Spigen one and replace it with: https://www.amazon.com/dp/B08S5WP4TN?psc=1&ref=ppx_yo2_dt_b_product_details&tag=tmc064-20
There have been a couple of time that the phone dropped due to a big pothole. Overall I love it. I also trust Apple’s electronics for charging more than some other vendors.
Thanks. just so i understand, there’s a part of the spigen onetap that I can take out? And then put in the spigen Mag fit holder? Do you think you can share some pics? Thamks
You have to remove a part from the one tap and also remove a part from the mag fit. Then you put the mag fit part into the one tap. That’s it.
Details: You take the part that has the swivel ball out by unscrewing the adjustment screw and pulling it out. (This is the part with the magnet that you attach the phone to.) The goal is to use the Apple charger so you remove the one tap magnet and replace it with a part that can hold an Apple charger.
I am traveling and cannot take a photo right now.
