Wood veneer cracking
Has anyone noticed this? I marked it down at delivery but at the SC they said the other model 3s have it so it's "normal"
It's noticeable when you look from the side and can see the surface isn't flat but had a bunch of raises cracked or separated sections.
Did you ever get this repaired? I'm about to be out of warranty with the same issue and I'm debating on putting in a service request.
If it's out of warranty, you should be able to fill a crack that small pretty easily.
Order some Timbermate - that's the good stuff I use for woodworking - and wipe the excess off with a wet paper towel (or better yet blue shop towel).
If you get the right color, nobody will know.
