As the title says, any idea if the above message would prevent the car from sleeping?
I just had an aftermarket stereo installed. They said they couldn't tap the penthouse because the car went crazy when they did (error messages) and wouldn't drive, so they ended up tapping the battery. And now I've got the above-noted battery message and the car won't sleep.
They said they checked the battery voltage and it's showing the same as another Model 3 they hooked their machine up to, so I've got no choice but to go through Tesla service. Just want to make sure there's isn't something else going on re: "no sleeping" before I do.
I've been reading about hooking up to the yellow wire (don't know where they tapped), but any recent/other tricks I could pass along? Everything else seems fine and they said they used transformers/resistors to prevent a surge (takes a few seconds to boot up, so makes sense).
Thanks!
Thanks!
