So then buy a hybrid.....
The goal is to not use any fossil fuels directly in the car. Seriously. Get a plug in hybrid.
Seriously. I can't. They don't steer themselves yet.
And I can put up with the inconvenience that comes with near double the power consumption in winter. But I don't like it, and would much prefer a better option.
so add an espar heater, nbd.
To all the people crapping on the idea of putting a fossil fuel heater in the car, do you all use an electric resistance heater to heat your house? Why not?
I also have a heat pump at home.No because it's terrible for efficiency and Ca title 24 makes it pretty tough But we are lucky enough to live in a geographic location where heat-pump based systems work just dandy
This is a similar system to what we have Mitsubishi Multi Zone Ductless Mini Splits
Sorry this jumped off heating-in-car but @Daniel in SD asked
They do use the motor heat to warm the battery but the motor is extremely efficient. If it's 95% efficient and drawing 15kW at 60mph then that's 750W of available heat.My brother tells me that the motors should be generating a substantial amount of heat. I'm sure Tesla has thought of routing the heat into the cabin somehow, but maybe it's not possible or maybe it isn't worth the trouble. Seems like that could reuse some power for heat.
Actually, that’s how the Model 3 generates heat... by using the drive motor. The Model S and Model X both have resistive heating elements, but the Model 3 basically vibrates the drive motor to generate heat.My brother tells me that the motors should be generating a substantial amount of heat. I'm sure Tesla has thought of routing the heat into the cabin somehow, but maybe it's not possible or maybe it isn't worth the trouble. Seems like that could reuse some power for heat.
When you use cabin heat in the Model 3, the motor controller causes the motor to generate more heat than it normally would.
Bjorn Nyland has a YouTube video that shows the power consumption of the drive train when the car is stationary and he turns on the cabin heat. I don’t have the time to find a link for it now, but later today I’ll post a link to it. It’s pretty eye-opening to see how much energy is used by the cabin heater at full blast
Mine draws between 3 to 3.5 kW win preheating the cabin. There’s also a noticeable buzzing coming from the rear end when this happens. Stater temperature of the drive unit increases when this starts, and you can see an increase in the battery inlet temperature as well indicating this heat is going to the battery.
The buzzing and power draw from the rear motor shuts off when I open the door, it doesn’t happen when I am sitting in the car. Just when the cabin is empty for some reason.
Mine draws between 3 to 3.5 kW when preheating the cabin. There’s also a noticeable buzzing coming from the rear end when this happens. Stator temperature of the drive unit increases when this starts, and you can see an increase in the battery inlet temperature as well indicating this heat is going to the battery.
Actually your car is drawing 10kW. 7+~3.
It would actually be quite a big deal. Mounting and fuel storage would be a huge challenge with the battery placement.
I love my car. Sometimes think about ways it could be better, though. That's all this is... It's got me through the winter so far, and I don't expect that will change.
I never said car. "Mine" referred to my rear drive unit.
I don't get why this is funny. But OK.My brother tells me that the motors should be generating a substantial amount of heat. I'm sure Tesla has thought of routing the heat into the cabin somehow, but maybe it's not possible or maybe it isn't worth the trouble. Seems like that could reuse some power for heat.
