X P100DL 72 amp charging rate just 45 miles per hour
Discussion in 'Supercharging & Charging Infrastructure' started by sammyfan711, Sep 28, 2016.
  1. sammyfan711
    sammyfan711 Member
    Downers Grove, IL
    My X P100DL 72 amp charging rate is just 45 miles per hour compared to my S 90D rate at 53 miles per hour with the same charger - is this because the X consumes more power per mile than the S?
    X 72 amp people - how many miles do you get?
    By the way, Lucille is a real treat to drive :)
  2. ggnykk
    ggnykk Active Member
    Earth
    Your car's instantaneous charging rate is kw. Which is amps x volts = 72 x 233 / 1000 = 16.77 kw (or u can switch the screen to show % state of charge, the kw number is shown on the left). Looks pretty normal if you have a HPWC, it is as fast as it get.
    the whatever miles/hour "charging rate" is incredibly misleading, and it is the actually the average charging speed over the entire charging session, NOT an instantaneous charging speed. A lot of people who are new to Tesla always get this confused.
  3. sammyfan711
    sammyfan711 Member
    Downers Grove, IL
    Makes sense - thanks!
  4. ggnykk
    Earth
    By the way, how much the cars (100D vs 90D) consume (wh/mile) has nothing to do with charging speed.
  5. shokunin
    shokunin P85 & M3
    Irvine, CA
    Yup as ggnykk pointed out...
    72a x 233v = 16,770w or 16.77 kw
    Charging also has some losses, so it's efficiency is around 90%
    16.77 * 90% = 15.093kw
    15.09kw / 333 rated wh/mi on X = 45mi hr.
    15.09kw / 280 rated wh/mi on S= 54mi hr.
    • Informative x 3
  6. AWDtsla
    AWDtsla Active Member
    NE
    It is not average charging speed over the entire charge, that will actually be a different number of you do that math. It slowly integrates towards the actual charging rate, where the integration time interval depends on how faster you are charging. It's going to basically max out soon after you start charging on a HPWC.
    edit - integration is the wrong word. It's more like a moving average, but still the averaging interval depends on the current charging speed.
  7. sammyfan711
    sammyfan711 Member
    Downers Grove, IL
    Driving both cars lately makes me appreciate the efficiency of the model S - those falcon wing doors on the X are just non-stop fun though!
    I've been close to 400wh / mile on the X compared to 280-290wh per mile on the S lately - I can see why the S broke the consumer reports' rating scale when they reviewed it.
    I have to say the model S is the car for me, all things considered
  8. TexasEV
    TexasEV Well-Known Member
    Austin, TX
    This is true for DC charging where there is a taper. With AC charging, what you see is what you get. If his car says 45 miles/hr (typical for a Model X at 72A), after 1 hour of charging he will have added 45 mikes of rated range and in two hours 90 miles.
  9. AWDtsla
    NE
    It is not this either. Charging rate on AC charging is practically the only conservative measurements of/in the car. You will typically get more miles than this reads.
  10. arg
    arg Supporting Member
    Cambridge, UK
    With AC charging it's closer, but there are still tapering effects. At the beginning of the charge, the current ramps up slowly so the miles/hr (average) takes a minute or so to catch up to the actual value. And when charging to 100% when balancing kicks in - once the display shows 99% (or however many miles corresponds to 99%) the rate of charge becomes tiny yet the miles/hr average still shows a significant value. I've often heard of people sitting waiting for a 100% charge to finish when they'd have been much better just setting off straight away.
    Things also get complicated when it's cold enough for the pack heater to get involved, though I don't think any of the instrumentation gives you a clear indication of what's going on in that case.
