X vs S charge rates on HWPC
Discussion in 'Model X' started by fiksegts, Feb 7, 2016.
Tags:
  1. fiksegts
    fiksegts Active Member
    Miami
    I get 58 mi/hr @ 80 amps for my Model S with dual chargers and 44 mi/hr @ 70 amps on my Model X.....
    does this sound right? I was expecting around 50 mi/hr....
  2. AEdennis
    AEdennis Active Member
    What's the feed? Might not be 240V service.
  3. fiksegts
    Miami
    shows 245v, charges as it should with the dual charger S....
  4. DrComputer
    DrComputer Active Member
    Sherman Oaks, CA
    According to the document in the My Tesla page you should get the following:
  5. Lyon
    Lyon 2016 S P100DL, 2016 X P90D
    Eugene, Oregon
    Sounds totally reasonable. It's 8 amps less and the Wh/mi usage is higher.
  6. proven
    proven Member
    Raleigh, NC
    Yeah, don't forget that the battery is the same size (90 versions of the S) but the range is lower. So even charging at the same amps will get fewer miles per hour on the X.
  7. fiksegts
    Miami
    thanks, looks like its charging as it should....
  8. FlasherZ
    Remember that the rated Wh/mi for Model X is higher, so the number of miles gained will be lower for any given number of Wh put into the battery.
    Also, the Model X seems to be more sensitive to higher voltages. For me, it will back down the charging current to guarantee the charger stays below 17.5 kW. My home runs at ~250V, and while the display shows 72A before plugging in, it'll drop to 69-70 when I plug in, based on the voltage at the time - unlike the Model S that will charge at 79A @ 250V all day long.
