so should I be charging on 120v instead of 240v? Seems like everyone is using standard 120v. This is confusing.
Change at lowest amps possible for your driving situation. Avoid range charging. Keep plugged in. I only use 240 for cooling an hour then back on 110v. Try not to deplete battery.so should I be charging on 120v instead of 240v? Seems like everyone is using standard 120v. This is confusing.
The battery will not be cooled during charging at 120v. I would suggest 240v medium amperage (around 30A or so) is the optimum, to balance battery temperature, charging speed, charging inefficiency overhead, etc.
If goal is to extend battery life.
Otherwise just ignore. Enjoy.
We are all dying we just don't have a declining ideal range going down weekly!
I stand by my statement. For battery longevity/health (if that is your goal).
The enemy of a battery is depletion, heat, and vibration. The two variables we control are depletion and heat.
As for heat - you want to prevent dendrites, lithium plating and thermal runaway.
Charge at the lowest amps you can tolerate for your driving style BUT if your battery / PEM gets hot (red bars) use 240v 16amp (lowest amps to initiate cooling AC of battery) then go back to 12Amps (110/220v either way). Keep it on a low amp charge as much and as often as possible to balance the pack.
Avoid if possible range charging and try not to get below 20-40% battery level.
Or better yet - just enjoy your car and know someone will come up with a replacement battery at some point.
My car lived in Seattle and is now in St. Louis. It was never range charged and never on anything but the standard 110v. It only has 10k miles. It was never depleted lower than 50%. I believe that is why it charges to 188 to this day.
I drive it now daily. I commute 6 miles round trip unless I am having some fun (which is daily - LOL). If the PEM/Battery gets well into the yellow temps or red I plug-in 16A / 240V for 1 hour then go back to 110V once cooling is done. I do not have OVMS or I would automate this process.
As for wear to the contractors I have reason to believe that is less an issue on 1.5 vs 2.0+. The earlier cars were over-engineered IMO.
Bottom line is the higher the amps = more resistance = more heat = degradation (with the exception of cooling >>> amp level). Obviously you need to replace the amount of KW spent driving daily or may want to take long trips but if you can minimize the heat generated charging by using lower amps AND keep the PEM / Battery as cool as possible you will be better off. I am confident in that.
Thanks for elaborating further. 100% agreed regarding the negative effects of heat on pack longevity. However, my point was simply that you can lower the amperage in the VDS to 12A on 240V charging without needing to stop the charge, unplug, and restart using the other cable. Have you tried this? Also, while higher amps in theory would equal more heat, the active cooling of the ESS that occurs during consistent 240V charging completely alleviates this! The best reason to lower amps to 16A or 24A is to prevent higher PEM temps.
The 110V cables are also very unreliable compared to the 240V or wall connectors, so I’d hate to see you burn through the cable sooner.
You must get OVMS as soon as possible! I waited five years of Roadster ownership before I finally got it, and I’ve been kicking myself ever since for not getting it sooner. It is the single best upgrade you can do for less than $160! Now, I can dial the amps down from my bedroom.
