Why does nobody call Tesla support before posting here?
I wonder if the charger (400 V to 12 V inverter) is working?Hey team,
Replaced my battery with a new OEM unit, voltage checks out fine, but warning is still on screen.
Any tricks or tips (i've tried a restart) before I make a service appointment?
I've found Tesla phone support to be pleasant to deal with and usually very helpful. They can pull logs from your car to see exactly what is going on.Because phone support is universally an awful experience, and because chat was closed for the night.
My presumption would be it is a stored code not an active one and is typically reset when a tech replaced the battery.Hey team,
Replaced my battery with a new OEM unit, voltage checks out fine, but warning is still on screen. Any tricks or tips (i've tried a restart) before I make a service appointment?
I've found it is something of a crapshoot. After-hours especially it can be a bear to penetrate the system to talk to an actual human rather than getting an automated "use your App to set up an appointment".I've found Tesla phone support to be pleasant to deal with and usually very helpful. They can pull logs from your car to see exactly what is going on.
Do you know how to perform a full reset (not just the display reset)?....After replacing the battery,
the replace battery notice was still there until he also disconnected the 12 volt dc to dc converter located under the rear seat.
So I ended up paying about $130 because I did not know that the converter needs to be disconnected to reset the notice.
Tesla Model 3 Hard Reset | Mountain Pass PerformanceDo you know how to perform a full reset (not just the display reset)?
I read a thread explaining on how to do it but I was not able to find it.
Had the same issue and this is how I cleared the messages. First disconnect the high voltage connector located under the passenger side rear seat. Second power down the computer (under Safety at the bottom of the screen…you need to scroll down). Third disconnect your low voltage battery (12v)…instructions for getting to it can be easily found. Lastly wait awhile..not sure how long but I waited 12 minutes. It may only take 30 seconds but I waited just to be sure. Reconnect LV battery then HV battery. Error messages should be gone.Hey team,
