Did a test fit with XXR 559, 18-8.5, +35mm offset and the one I got worked on the fronts. Didn't test the back : big mistake
XXR 559
got all 4 with Michelin Cross climate+ mounted up : only 3 of 4 clear! Back left is hitting the caliper. But back right clears! what gives?
Ended up grinding down the little squares on the caliper where the molds must have been down just a teensy bit bigger. Not even into the actual caliper, just the edges of those squares. Guessing that one of my calipers had a tiiiiny bit more metal. Now clears.
Of course in the back there is virtually no clearance. Front has plenty. Overall looks good to go now and the caliper paint that is missing is not visible at all.
Rim mounted (looks nice!)
Caliper we had to grind (slightly) in rear left. Can't tell at all now.
Caliper that didn't have to have anything done (rear right). Very little clearance
Front with plenty of clearance
Overall my lesson: fit test on all 4 spots next time!
XXR 559
