Here is my conversation with Nolan at Tire Rack. I am really getting close to pulling the trigger on these Bridgestone Potenza RE 11's...
Thank you for choosing Tire Rack. A product specialist will be with you shortly.
You are now chatting with 'Nolan'
Jordan: Hi there, I have the Yokohama AD07 on the back right now, but am looking for a more cost-effective solution.
Nolan: Hello Jordan, how may I help you?
Jordan: I was considering the AD08's but someone suggested the Direzza Sport Z1 Star Spec
Jordan: The car is similar to the Lotus Elise, but is about 30% heavier at 3000 lbs.
Jordan: I was told that the Dunlops are actually stickier than the AD08's. What can you tell me about their weight-handling ability?
Nolan: I can help with that
Nolan: Both tires have a focus on the dry grip and are not going to be the best in the wet. Do you have the Yokohama AD07 on the front and back currently?
Jordan: I don't track the car, and most of the time I don't drive too aggressively (but I do like to accelerate from the light from time to time ;-)
Jordan: As far as I know, the AD07 is the only tire available on the front.
Jordan: I live in Florida, so it doesn't get too cold here, but it does rain. Normally, on rainy days, the car stays in the garage, but I do get caught in the rain from time to time.
Nolan: The Dunlop is a great tire and one of the top rated. What is the front and rear sizes you are running?
Jordan: 225/45R17 in the back and 175/55R16 in the front
Nolan: one moment while I take a look
Nolan: You are correct, the only matching are the Yokohama. We don't recommend mixing tires as it will cause more unpredictability in the handling of the vehicle. It can be done, but not recommended
Jordan: I have read this also. A lot of other owners are going with the AD08's in the back as they are significantly cheaper and give a little longer life. I was told the Dunlop's are even better at traction and life expectancy. The problem, as I understand it, is because the Roadster is so much heavier in the back and has such incredible torque, it eats the rear tires (6-7K miles, if you are lucky!)
Jordan: Another issue is that the Roadster uses a sensor on the front wheels to monitor rotation. If the rear wheels rotate too fast, it engages traction control. As long as the rear wheels are more sticky than the front, I think this will be OK.
Jordan: Sorry - too fast in relation to the rear wheels.
Jordan: Can the Dunlops support the extra weight?
Nolan: Yes, this can handle the weight
Jordan: And would you agree that the Dunlop's are stickier than the AD08's and may last longer?
Nolan: They will both be a very stick compound. The AD08's currently hold our track record in the dry. The Dunlop
Nolan: The Dunlop would be better in the wet
Jordan: Ahhh so how "close" are they in dry and wet conditions?
Nolan: Click here for the survey ratings
Jordan: So if I'm reading this right, the Yoko's are a little more comfortable, better in steering response, quieter, and have a better treadwear?
Jordan: As far as steering response goes, if they are in the back, this does not apply, right?
Jordan: How much are the Potenza's?
Jordan: When I go to the Potenza page, there is no price.
Nolan: one moment and I will take a look
Nolan: The RE-11 is $212 per tire for the rear size
Jordan: I assume they don't have one for the fronts?
Nolan: Unfortunately they do not
Jordan: how do the AD07's and RE-11's compare as far as stickiness and composition?
Nolan: The RE-11 is going to be the stickiest tire with the most grip available for a street tire.
Jordan: And they can handle the weight also?
Nolan: Yes
Jordan: Excellent! I am posting in the Tesla forums now to see if there is anyone with experience with these tires. I know there are many who are using different front/back tires. This may be the solution for me. Thanks very much for your help. When I go to purchase them, should I mention your name?
Nolan: Please do and I will be able to monitor your order as well. If you have any further questions, feel free to contact me at 1-800-428-8355, option 3, ext 173 or
[email protected]
