I do like driving above 80 MPH but I am too worried of getting pulled over in the middle of the country so I don't even chance it. 70 MPH pretty much is perfect to go any where in USA. In TX 70 MPH is a bit too slow but folks just go around me or I pull over for them to pass when its a small road. But yes arriving at 5% would always be ideal but i have seen recently too many Ss dying at 17% ish for me to be comfortable risking my biscuit.It was about 1,100 miles total. For me it ended up working out driving faster (about 90) cause I wanted to get to the next station with 5-10%. And if I drove 85-80, the arrival % was 15-20%.
I think next time just to see, I may go one way at 75 and see the end results, but when entering everything into ABRB, it said 85mph was the shortest arrival time. I had to adjust all the SOC arrival and charge stops percentages to 40 or 50%.
No problem at all. I just love sharing info. Yes the flowers are always there we just need to slow down every now and then and smell them. It's good for us.Thanks for making this log, and yes we all need to take time to stop and smell the flowers!
I can highly recommend a set of 20"Mx slipstreams on a p85 , noticeable improvement in rear grip and cornering stability due to wider tyre and less side wall. they look great on the car and don't rub , they fill the wheel arches nicely although more prone to kerb rash as they sit further out , less pothole protection than the 19" with slightly more tyre noise and a small efficiency impact .What tires/rim combination are you running? I have a similar car to yours (late 2014 P85+) and was considering switching from my 19" slipstreams to a set of staggered 20" Mx slipstreams, but thought I would gauge what other vintage cars are running.
Are you staggered? or squared?I can highly recommend a set of 20"Mx slipstreams on a p85 , noticeable improvement in rear grip and cornering stability due to wider tyre and less side wall. they look great on the car and don't rub , they fill the wheel arches nicely although more prone to kerb rash as they sit further out , less pothole protection than the 19" with slightly more tyre noise and a small efficiency impact .
After listing things like that it sounds like more downsides , for me 19" to 20" was was a better choice than 19" to 21"
Staggered with the Mx 20" R 275/35 , F 245/45 ,Find it to be a more stable ride, epically on smaller roads here in the uk where some have quite a concave shape from the middle of road to edges, helps water run off towards kerb and drainage . With the 19" I'd notice the car tracking the camber of the road towards the kerb with no steering input . Less noticeable on the 20" .Are you staggered? or squared?
I find that on my 19 inch wheels and tires (square setup), the S wanders left and right a lot at high way speed. I have had my suspension checked and they continue to say its crappy tires...which I agree with as I dont feel that much wandering on my 21 inch wheels and tires.
re charging , looks like the louvers are working based on numbers from smt app . worth a visual check to see if numbers match louvers actually opening.
Over the past weekend I was driving and go a random message "Car Needs Service. Car May Not Restart". Very strange. My Model S worked like a charm still. Was on for about 5 minutes then went away. I didnt think much of it. So called Service Center, and they pulled logs and said "It could be the Battery Heater, if it goes out you will need a tow to the service center. Bring in the car asap." So ok no sweat, I scheduled an appointment.
Dropped the car off the next Wednesday, and later that day got a text stating that I need a new Drive Unit. I was like wow. really? Ok well its covered under warranty so ok. But that got me thinking, isn't it a bit crazy that I had not drive unit issues, never heard a peep, or even a buzz, my energy usages had gone from average 350 to about 450, but hey its winter and I use the heater all the time. So not complaining but very strange.
I share this to you all, so that you take it serious when you see that warning too. Good luck. I will update you all when I pick up my car. I got a loaner MS70D so not complaining at all.
Current mileage: 60,304
Warranty expires: May 2022
Warranty expires at mileage: 41,459 + 50,000 = 91,459 - current mileage = 31,155 miles remaining
Keep in mind the note on the max power rating, as this isn't generally achievable with a Model S battery pack due to high voltage drop under load. Current is the limiting factor in a Model S.Also recently found this on 057 website and thought it is good info to know about the old base drive units. At least the one used in my S.
1002633-00-Q - DRIVE UNIT - BASE
Thanks for clarifying. So my S probably at best making 300kW? hahah all good. I love this info so wanted to save it so I can always refer to it. Thank you again for all you do for us out of warranty Tesla owners. I plan to buy the warranty with yall shortly.Keep in mind the note on the max power rating, as this isn't generally achievable with a Model S battery pack due to high voltage drop under load. Current is the limiting factor in a Model S.
245/40/20 - Front tires on 20 x 9.0 Model X Slipstream wheels
275/35/20 - Front tires on 20 x 9.5 Model X Slipstream wheels
Says 70 MPH on dash, but speedo app shows 69 MPH.
If you're comparing these to the stock 19" tire size 245/45R19, the fronts have the exact same outside diameter (so no speed difference), and the rears would read only 0.2mph slower.
Try plugging in the sizes into this helpful website: Tire Size Comparison
Probably just rounding error.
Also, 41/42 PSI seems a bit low. Most people run 45PSI cold, unless you're doing it for a specific reason.
Thanks for that info on the PSI too. My door jamb actually states 42 PSI so I generally run 42 to 45.
Thanks. I will try going higher. I wonder if they recommend it so that we get the most miles out of our cars...because the max PSI on my tires are 50 psi.Tesla has flipped-flopped on this since 2014. At first is was 42psi recommended (hence the door jamb), but now they suggest 45psi if you ask at the SC (and also seems to be the general consensus). 42 is probably OK, but I wouldn't let it go below that. My tires are 45psi cold and 49-50psi hot.
