The last line of your other post sounded a bit like obsession to me, but I will apologize for mis reading it.
We're good, it's a forum
At her final destination for next few days, my wife forgot to reset the limit to 90% before charging overnight to full. She has access to a hotel HPWC for the next few days. Checking through the API, charge state shows battery is at 98%, ideal battery range is 296, estimated battery range is 264. When back home, we'll set the limit to 90%.and track the charge state over the next few cycles.
charge_state:
{"response":{"battery_heater_on":false,"battery_level":98,"battery_range":296.86,"charge_current_request":6,"charge_current_request_max":6,"charge_enable_request":true,"charge_energy_added":32.12,"charge_limit_soc":100,"charge_limit_soc_max":100,"charge_limit_soc_min":50,"charge_limit_soc_std":90,"charge_miles_added_ideal":131.0,"charge_miles_added_rated":131.0,"charge_port_cold_weather_mode":false,"charge_port_door_open":true,"charge_port_latch":"Engaged","charge_rate":0.0,"charge_to_max_range":true,"charger_actual_current":0,"charger_phases":null,"charger_pilot_current":6,"charger_power":0,"charger_voltage":2,"charging_state":"Complete","conn_charge_cable":"SAE","est_battery_range":264.57,"fast_charger_brand":"<invalid>","fast_charger_present":false,"fast_charger_type":"ACSingleWireCAN","ideal_battery_range":296.86,"managed_charging_active":false,"managed_charging_start_time":null,"managed_charging_user_canceled":false,"max_range_charge_counter":2,"minutes_to_full_charge":0,"not_enough_power_to_heat":null,"scheduled_charging_pending":false,"scheduled_charging_start_time":null,"time_to_full_charge":0.0,"timestamp":1569066415489,"trip_charging":false,"usable_battery_level":98,"user_charge_enable_request":null}}
