I'm mentioning this in hopes someone points to what's been rattling in my head.
If I'm recalling correctly (and I may not be), the range "upgrade" the newer models got (e.g. from 386km to 402km, that's 240mi to 250mi for you miles folks) interestingly came with an elimination or massive reduction in the hiding of initial battery degradation (which is rapid at beginning of life for a couple percent, but settles very quickly).
So basically, when I got my 499km advertised range 2019 LR AWD, it had a "buffer" before it starts to report lower expected range due to degradation. And indeed, it took quite some time (well over 20,000km I think?) before that number ever went down. It was losing capacity that whole time, but they gave themselves room to play with basically.
The newer ones,
if I'm recalling correctly, either have no such buffer or a very small one. Thus,
any degradation is immediately apparent. And because not every battery is made equal, they can report less than 402km range from brand new (but will be close). Basically, instead of my era where it's delivered with a cap of reported range, they're now showing you the actual capacity via rated range properly.
Now,
if this is true, you have all sorts of follow-up conspiracies, but also some truthful information:
- Newer Model 3s with the 402/518km (250/322mi) advertised ranges will only sometimes (maybe rarely) be delivered and be reporting that much range. But it should be close.
- Newer Model 3s will appear to degrade faster than the older ones (since they would show lost capacity immediately), but in truth they're the same.
The benefit to this approach is they can put a higher number on their webpage. The flip side is the more
apparent degradation point, even though all else is probably equal.
I would
love if someone corrected or corroborated what I've said, because I cannot find the references that initially led me to this belief.
