cwanja
VIN can be assigned whenever. Depends on when the car begun manufacturing.In other words, your VIN was assigned prior to Oct 1, correct?
Where is Sirius XM? I have not seen that on my car. Also it seems that only Slacker Radio and Spotify are available for streaming. Are these the only options?Very impressive. The only changes I can see are #9. Sirius XM has been enabled as of a month or so ago. And #10. I was not aware the active noise cancellation has been enabled. Which update turned that on? Otherwise this post could save a new forum member a lot of time. Good job.
Let us know if you finally get the car. I heard from a reliable source things were VERY slow this past weekend at the Fremont factory.I have a delivery date of Oct 5-10 with a VIN# (M model year) that keeps changing once the date is here. A few says ago it was Oct 3-8. A week before that Sept27-30 and so forth.
slow on purpose?Let us know if you finally get the car. I heard from a reliable source things were VERY slow this past weekend at the Fremont factory.
supply chain issuesslow on purpose?
RN# 114449741 VIN# 41735 Picked up in Nashville 9-26-21Last Sunday as in yesterday? VIN contain MF or NF?
Different steering wheel. Who knows, it obviously wasn’t engineered to have one. The worm on my most recent is hardly noticeable unless you are looking at it and light is hitting it at just the right angle to make a faint shadow.That’s interesting. My 3 didn’t have one. Why is it on the S?
Yes. Got VIN on Sept 25thIn other words, your VIN was assigned prior to Oct 1, correct?
Mine is under streaming options, I had to call sirius and give the radio ID number located in the top left corner (they couldn't find it by VIN number) and they said I had 3 months free, 6 hours or so later it was working.Where is Sirius XM? I have not seen that on my car. Also it seems that only Slacker Radio and Spotify are available for streaming. Are these the only options?
It should be on the same page as Spotify and Slacker. I remember reading in this forum awhile back where SiriusXM suddenly appeared after an update. Not sure which version of the software the car needs, but I suspect yours isn't up to date for some reason. Others have reported not getting the newest software yet.Where is Sirius XM? I have not seen that on my car. Also it seems that only Slacker Radio and Spotify are available for streaming. Are these the only options?
My SiriusXM disappeared today after being available consistently for the last few weeks. I’m running 32.20.1.It should be on the same page as Spotify and Slacker. I remember reading in this forum awhile back where SiriusXM suddenly appeared after an update. Not sure which version of the software the car needs, but I suspect yours isn't up to date for some reason. Others have reported not getting the newest software yet.
Giving the workers a break after busting their butts for the last month?supply chain issues
Yipes. 32.10 restored it back on September 15th. Do you still have immersive sound? There was a reboot procedure back in July that involved disconnecting the 12 volt battery that restored it for some people. That seems extreme, though. Your post is the first I've seen where it has disappeared again.My SiriusXM disappeared today after being available consistently for the last few weeks. I’m running 32.20.1.
Here is the link that discusses some of the things that helped prior to the update...My SiriusXM disappeared today after being available consistently for the last few weeks. I’m running 32.20.1.
Did u change ur order at some point or not complete the steps right away? Your edd should be late oct early nov. Does not make senseAnd now I just got pushed back to 12/11-12/31
What is your order details? Mind adding them to your signature / custom banner as well?From Oct 19th-Nov 8th to Nov 02-Nov 30th
