EasyPal
@EvilStryke, I took another closer look at my liftgate glass, it is also bowed in the middle (above the roof glass), not flushed. I will add it to my Service.They only did a road test I guess. My liftgate glass is flush with the Top Glass and all looks fine from outside after adjusting the 4 rubber stoppers.
However, from inside the trunk with cover closed, I measured the gap between the "loop" and the trunk body edge. The driver side gap is about 2mm wider than the passenger side. In my case, the seal tightness is not balanced between left and right. I explained to a service advisor (in the Peninsula) but did not have a chance to meet with a technician.
I heard that in Fremont SC, technicians sometimes meet directly with customers to explain issues and resolutions together with service advisors.
