First post - went to swap the mid-bass door speakers on my 24 RWD car for Audison AP8s using the Amped Garage 3d printed adapters and the factory plug seems to have changed ?
The green plug I had pre-wired to the speakers and seems to be the standard plug supplied with kits from multiple manufacturers so looks like they have changed it for the 24MY.
It looks like the plug is made by the same supplier but is a mirror image of the previous years from the photo of the speaker connector.
I found a supplier in the UK but should be available from other local sources:
Just in case it is helpful to anyone else as I have had to put the door back together and order/wait for the proper connectors..
Diameter of hole in door is 170mm (6.8 inches) but the window mechanism limits depth in the door. The thin plastic surround flaps around when you have removed the 8mm bolts and speaker..
BTW The sound deadening sheet on the outer skin was properly rollered after the photo!
Thanks
Gavin
2 Way YAZAKI YES Kaizen Connector 1.5mm(060) Male Light Grey
Stockists of a wide range of electrical and wiring products for the Automotive and Motorsport industries. Connector housings, terminals and accessories.
www.automotiveconnectors.com
Thanks
Gavin
