21" Uberturbines Square set up on a LR MY
Hi Steve!
What mud guards/flaps are those on your Model Y? They look really good!
Thank you!
Hey! I got them from Amazon. It’s not bad in terms of looks, but I also had PPF installed on the bottom parts of my doors in case it doesn’t completely block all rock chips. If you buy these, also use more double stick tape for a secure fit.
A-Premium Set of 4PCS Mud Flaps... Amazon.com
Since they don’t come with Caster; Keep an eye how the tires are wearing; If you see more wear on the inside, to correct that problem you must have adjustable caster when doing a wheel alignment.
Check out Amazon for best price: Rear adjustable Camber Kit.. about $160
Another $100 to install them and Boom a wheel alignment $120.. your tires will wear out evenly and therefore last longer..
Most 21’ 22’ tires are directional; You can’t turn them around; On the tires it tells you Outside and Inside.
Huh? Caster or Camber? Not sure what adding caster in the rear is going to do? MY doesn't have rear wheel steer.
Reactions: Scubamikey
I did a square set up on my Model Y LR as well. However, I did 4 of the "fronts" with 10mm spacers in the back.
265/35/21 all around. The Hankook EV tires - so far I like them... only has been a week though...
Yup still love it since the ride is surprisingly more comfortable than my original inductions. I also took some photos just now with the wheel turned all the way out to show clearance.
Reactions: TomB985
