It wont be an SR battery I don't think. the M3P has had at least 3 different sizes of battery since 2019So, no messing back and forth, they did some remote checks and they have fitted a battery with the wrong capacity. Does that mean from a SR or just a really old poor quality one? Not sure but but they said sorry and will replace it to as it was. They have all the measurements from my last 3 packs and can see what I had and what I now get.
They have 4 weeks to get it fitted before I deploy for the rest of the yearā¦.
Oh no! I thought it was goodāun this timeAnd itās back in the garage for its third replacement.
Letās see what second hand nonsense they palm me off with this timeā¦.
good luckAnd itās back in the garage for its third replacement.
It was better but as it settled down it became as rubbish as the previous replacements. Hopefully this will be the one!Oh no! I thought it was goodāun this time
Teslamate - thereās a thread on the forum about it.Watching with interest! (And good luck)
Did there used to be a self hosted equivalent of Tessie and TeslaFI? Is it still going? Ah, but it will be missing the fleet data won't it?
Slightly early update aboveThird time lucky then - Hopefully.
Clearly they are now aware your not going to be side-lined or thwarted in your pursuit of getting what you should be entitled to, they have tried twice and it must be getting a bit tedious for them now keep pulling your battery out. You haven't gone away and haven't just accepted It is what it is - Surely Its in their interest to deliver you absolute perfection just to get rid of you.
I have to admire your fortitude and resilience, You are a businesses worst nightmare If they don't get it right, I can imagine the service centre managers fingers crossed your deployment gets extended. Well done you - your an inspiration. - I'm so looking forward to an update some time after your return.
are you sure about your original range figures. I was under the impression that the M3P had 315 miles of EPA range when new and that is the figure they display in the car which means if your car had 280-289 miles of range at 90% then it had 311-321 miles of range at 100% which is as much or more than it had when new which seems unbelieveable. I would expect at least a 5% drop since that usually happens fairly quickly which would have given you a max range of 267miles at 90%. For reference my well treated M3 LR lost 9-10% in 25Kmiles going from 310 to 280-285 miles at 100% so 255-257 at 90%.Sooooooooo, battery number 3 is in! They charged it to 80% on sat and the range wasnāt great. Today they put it on a fast charger to 100% andā¦ā¦..itās no better!
273 miles at 100%. A loss of 43 miles (or 13.3%) if my maths is correct - after 20 months of ownership) I had 280-289 miles at 90% before battery number 1 failed.
Again, my maths, but I am 27k miles into a 120k mile warranty (20 months into an 8 year warranty) and already at half of the requisite loss to qualify for a new battery.
Iāve submitted an FOI request for all of my battery readings and will see what happens but I intend rejecting the latest second-hand, substandard palm off. My mileage and age of the car is almost irrelevant as itās been in for 3 replacements and spent nearly 2 months in the garage so far. I donāt want a new car, I donāt want an ICE car, I want and love this car. This does (DID) what I wanted and needed.
Unfortunately I deploy overseas tomorrow so canāt check this battery until the winter, but I know they donāt get better as it gets colder.
Given Tesla donāt contend a lawsuit if they are in the wrong, anyone got any thoughts? Iām no lawyer, but I know whatās right and Iāll happily fight for it.![]()
This is where having TeslaFi (or similar) is useful, as it keeps a record of ever charge received by the car. This information (along with other recorded data) would be good in proving if the replacement battery was not up to scratch!are you sure about your original range figures. I was under the impression that the M3P had 315 miles of EPA range when new and that is the figure they display in the car which means if your car had 280-289 miles of range at 90% then it had 311-321 miles of range at 100% which is as much or more than it had when new which seems unbelieveable. I would expect at least a 5% drop since that usually happens fairly quickly which would have given you a max range of 267miles at 90%. For reference my well treated M3 LR lost 9-10% in 25Kmiles going from 310 to 280-285 miles at 100% so 255-257 at 90%.
If your battery was faulty maybe the range readings you got before it failed were also misleading?
I am not saying you are wrong about the "new" battery being poor just that the baseline you are measuring it against does not seem quite right so the gap may not be as much as you think.
That sounds about right for a 2021 model with the 82 kWh Panasonic battery. The newer 2022 model with 79 kWh LG battery is less.I was under the impression that the M3P had 315 miles of EPA range when new
Well, It all sounds like a bit of a farce, You wouldn't think they would call you to tell you its not good news, the only possibility apart from another duff battery could be -Slightly early update above![]()
The BMS would be a tad confused as it knew the KWs in and out of the battery they took out but wouldn't know anything about the replacement - so wouldn't be able to reliably predict range, the car may need to be run down to as low a % as you dare and then fully charge it - this way the BMS has a baseline to work from and will monitor just how many KWhrs goes into the battery and therefore able via its algorithms to work out a much better guess of range.
