Interesting...i was under the impression from the multiple batter threads I’ve read that 70% SoC is ideal for battery longevity and minimizing degradation.
It's complicated. And there are multiple schools of thought.
I think that Tesla's position is that the batter is built so that you don't have to worry about it. Their calculations and warranties take all sorts of battery regimens into account and you they are still estimating 300,000 mile range of the Model 3.
That said, they have suggested that continuous charging to 100% isn't optimal, as long as you drop it below 90%, life should be good.
Now, from that, there's all sorts of FUD, misinformation, bad information, and wrong information floating around.
The batteries in the Model S/X and the Model 3 are different and in the S/X there have been multiple formulations over the years.
Batteries can be optimized for longevity, capacity, charge rate, temperature and a number of other variables. As with many things, you make one variable better, the others often suffer. Many of the studies that people reference are often based upon generic cells, cells that are designed for other purposes and often with different criteria. Cellphone batteries are one example that many studies are built upon and have very different goals 2-3 years is all that is needed, it's capacity and weight.
Tesla hasn't released that much on the batteries, so there really isn't a lot of information out there.
Okay, so why do I make the suggestions that I do?
First, there are hundreds of "my battery is degrading posts" and none of them really are. Battery capacity calculations are guesses and there are a number of factors that go into the calculation, so it's all pretty bogus to begin with. You'll find that out during your first winter.
Allowing batteries to balance their charge is helpful for the battery pack. If one battery has a lower voltage, then the pack has a lower voltage and all sorts of things aren't optimal. My engineering tells me that the batteries aren't going to equalize well until they are all at max voltage which equates to 100% charged. That also seem to be a point in which the car recalculates max charge and brings the max back to a more realistic guesstimate. You really can only know when a battery is fully charged after you pour current into it and it doesn't accept anymore.
Keeping it at 70% has been proven will result in estimations that vary from reality. That's what causes many people to start complaining.
Charging to 100% helps fix this and doesn't damage the battery. The battery was built to be able to charge to 100%. Matter of fact some of the highest mileage cars regularly charge on Superchargers and near 100%.
Every few months going to 100%, well, first, get out of the house, take some trips and enjoy life. Charge to 100% when you do and everything is better.
