OK,
To try and unravel the mismatch previously reported I charged in Standard Mode at 16 amps.
Set charge to begin at 3AM and charging started at 16amps and concluded at 4:15 (didn't drive much yesterday) with the Tattler reporting a 97% charge of 181miles.
At 7:00 when I got into the car the VMS showed 181 miles. No clue what the display said at 4:15 cause I was asleep.................. any help?
CAC=150.16
Oh and the roadster slide switch....... been there done that..............really annoying when I do that!!! Usually only happens when the ship is flying at three sheets to the wind.
Generally when I charge, the Tattler gives me a percentage of charge relative to the charge mode. I play with the KWh average and the ideal and est mile figures because I find that that allows the car the charge closer to a 100% of the Standard Mode's potential........ or gives me a higher ideal milege figure. If I get the speedometer display 5-15 miles above the VMS display the Tattler reports a 100% charge and then I get around 186....... if the mile differential is reversed..... which is normal ..... the Tattler reports a charge of 95% to 98% before the charging cycle cuts off. The reading is then in the low 180's( or even 179 as lowest I remember). Based on previous comments and the work by Tom Saxon and EV America I guess the lower figures are consistent with the CAC/ milage work. Maybe when I reverse the Estimated and Ideal milage figures I fake the PEM out and it gives my high milage..... I don't know.
CAC=150.16
